Hey guys just spent the day swapping my 68 ps "pinky" box to a high effort 2.5 lock to lock box, couldnt see the paint markings on the box to see exactly what it is but got it off another forum member that said it was off a iroc. Anyways also bought a new ps pump for cheap insurance. The new pump's pressure port was for a female hose fitting, I pulled off the old pumps male fitting and swapped them out. While changing the fitting I also swapped out the pressure and flow valve with the old one. I did this bc the new fitting didnt have a hole on the side of the tube and I noticed the old one was notched where it meets the valve body. I'm guessing it was for oil flow since their was no hole drilled on the side of the tube. I drove the car around, I'll def have to get used to this box. Wow 2.5 lock to lock is awesome. I didnt realize how much effort you need to spin the wheel compared to the old box. I'm certain I need an alignment. My car tracks left and right and I have to fight the rails to stay straight. I have two questions for you guys. Any issues with me swapping the guts from the old pump to the new one? I saw some forums where I should have drilled out the port or pulled a shim for more flow/pressure. I didnt is that an issue? Second question is what's good specs for an alignment for the car? I dont track it just have fun on the street. Thanks guys!
