Here you go:
1967 Chevrolet Camaro Z28 | eBay
Gar, I have seen this 'angled rear bumper corners' several times as well. This may be due to the qtr panel holes in wrong place, rear brackets by license plate wrong or not adjusted correctly. One would think in adding washers between bracket and bumper for straightening the corners out, at least I would.….and none came with Z badges.
Ev, what do ya suppose causes the rear bumper to droop in the side views ? Is it the bumper itself, the mounting brackets or is it misplaced holes in repro quarter panels ?
A peeve of mine that shows up way too often on 67/8's !![]()
I think the grill is all there, but has been painted (too much gloss) and the front edge of lower piece wasn't masked off. Should be bright anodized aluminum showing, but is painted black.Missed that bumper the first time.
Also isn't part of the grill missing?
