21 - 40 of 73 Posts
Yeah, I need to keep looking for a spot inside the car
Depending on how big it is, you may be able to hide it under the front on the center console. I have component speakers in my car and thats where i hid the crossovers.
From memory that looks like it’s big enough
It seems that the dimensions from internet says it will allow 2.25 pass through. I used a door knob hole saw 2.125 ? and it was a very tight squeeze.
so drill or bore through a piece of scrap before you commit to a size, and test the harness pass through. …it would have saved me some hand work with a rotary file if I had done that.
Discussion starter · #25 ·
2" was more than enough. Working my way through coil brackets and Ignition box brackets.. but I'm getting there.
😆 I was just thinking how bada$$ you were, wrestling all that stuff through that grommet. I made a mess of the one I had!!
I have a tendency to pick the file specks out of the pepper, so I made my own, out of a piece of aluminum and some sheet rubber that I had laying around.
Also used this to make the one for the clutch rod penetration in the fire wall. I might have done that for the Speedo cable hole to ……there’s a lot of holes in the firewall.
Discussion starter · #28 ·
LOL
I've found that some sound deadener like boom mat or Noico 80mill makes a pretty good hole cover'er
Discussion starter · #29 ·
Ok, so i've mounted the ECU under the passenger seat and i'm playing with the wiring. What wire feeds the tach? I can't seem to find one to go to my tach. On my HEI, I had the red (batt) and a green (tach) . I'll use the red as my switched ign source but what feeds the tach wire?
Is a red battery wire really a switched ignition source? Battery implies not switched. Switched power needs to be switched and is generally pink.
Don
Discussion starter · #31 ·
Don
I am going to test the circuit first. I'm pretty sure it's the one coming out of the fuse block from the ign fuse which I believe is a switched power. Work has me running so crazy right now that i don't have time to spend more than a minute on it so it'll be this weekend before I can play with it serious so I was just inquiring.. Thanks
Discussion starter · #33 ·
If I understand your question….
Page 13 from the pdf.
“Optional] Tach Output – Color = Blue with white stripe – This wire provides a 12v square wave output and can be used to trigger a conventional tachometer.”
I don't have a blue/white wire :cry::unsure:
Discussion starter · #35 ·
Ok ….what version are you using. Terminator, sniper, Dominator? Maybe there are different harnesses.
Terminator X
Just got off the phone with Holley Tech, My harness does not have that wire pre wired so I have to "pin" my own on pin "A28" on the larger ECU connector or pin "H" on the ign harness at the distributor connector.. if I understood him correctly
Discussion starter · #38 ·
Ok ….I’m using the X Max so there’s the difference I suppose.
I like easy….and $25 isn’t a lot 👍
$25 is cheap in the grand scheme but expensive for one wire.. I really want to get this done over the weekend so I'm going to see what I can do to pin it myself
Discussion starter · #40 ·
Where are you guys connecting your vacuum line for the MAP sensor?
9.3.9 Manifold Absolute Pressure sensor (MAP)
[Required] For naturally aspirated & nitrous engines, you can connect the internal 1Bar MAP sensor located on the ECU to an available intake manifold port by using the appropriately sized quick-turn adapter.
The only manifold port I have is a 3/8 for the brake booster. Can I attach a vacuum line to the small nipple on the carb throttle body base plate? OR????
21 - 40 of 73 Posts
