On a base model 68 with factory air, but manual brakes and manual transmission, does the vacuum canister on the driver's side under the fender have any use other than when the AC is on? Is there any harm in plugging the vacuum line from the intake to this canister? The AC doesn't work anyway and I'd like to alleviate any question of a vacuum leak.
Bonus question: if I install a Vintage Air system is there any use for the same vacuum canister? The VA instructions indicate disconnecting the vacuum in the driver-side kick panel, but I don't see other references after that.
Thanks,
Kris
Thanks,
Kris
