I am using the Mcleod hydraulic clutch conversion kit for 67-69 Camaros. I recently was able to get the car fired up and I have taken a couple of trips around the block. I have been having issues shifting into first gear when trying to shift while slow rolling in a parking lot. I assumed it was either a bad synchro or the clutch not releasing when pressing the hydraulic clutch system. Yesterday, I used a mityvac and was able to get all the air out of the system, I think. I had good pedal pressure and it seemed to go into gear easier when at a stop; however, the first time I tried to shift when rolling at slow speeds the transmission grinded again but when at a full stop it goes into gear with no issues. So, I took it for a 25 min drive to get some HP tuner data. After about 20 mins, I noticed when at a stop it started slightly grinding into first and the pedal release seemed to be getting closer to the floor. I do not seem to be losing any clutch hydraulic fluid but I am losing pedal pressure. The only thing I can think of is a damaged seal in the clutch master cylinder. Any thoughts?
