Situation: I actually am working back and forth on 3 projects right now, 67 Camaro, 92 Camaro, 76 Boat Trailer. The 67 Camaro is on my rotisserie and is longer term project. The 92 Camaro is probably highest priority (rust out repair, repaint engine bay and various rust repairs) as I need to get it back on the road due to gas prices (its a V6). The boat trailer is whenever but I need it done by spring. Any sandblasting has to be done outside as long as the weather continues to hold up (Washington State so not much longer this year). The goal is to get a portion of the welding, blasting and paint coating on the areas that allow me to move everything into the shop for other winter work that doesn't involve blasting or sanding. The way I work on these is to do small areas at a time so I don't use the paint very quickly. Except for the boat trailer, the work I am doing now is all hidden except the engine bay on the 92 Camaro so I don't need a 2K primer over the epoxy.
SPI Products: I am concerned with shelf life as it will take a while to use the paint. I just got off the phone with SPI and they said that their epoxy primer has a 2 year shelf life after opening and their epoxy activator has a 1 year shelf life after opening. They said anyone's single stage or base/clear can go over their epoxy. They also said the topcoats can go directly over the epoxy primer.
So, here is what I am now thinking after the info above and talking to SPI:
1) Sandblast or sand
2) Shoot 2 coats of SPI epoxy primer (Buy 1 gallon of epoxy primer and then buy 1 quart at a time of the activator as needed)
3) Shoot 2 coats of Omni single stage topcoat for added protection even though areas are hidden
Later when I paint the two cars, I will use Base/Clear for those.
