21 - 33 of 33 Posts
Dave,
I had been curious about the feasibility from the point I had committed to the LS3.
I only saw one picture of this setup when looking for verifiable evidence of the concept.
I don’t think it’s a substantial benefit, but it can’t reduce performance.
I did like the idea of a common and inexpensive filter.
Can't hurt, looks great, the whole car, what I can see, looks amazing. Cold dense air = good. It also keeps out the turbulent air underhood at speed & fan/fans from disrupting proper fuel atomization.(y)
As far as heat rising, when the car is on the road heat rising is a non factor because air flow through the radiator changes flow in the engine bay from natural to forced convection.
A cowl hood brings in external cool air that has a boost because of the high pressure area at the base of the windshield which cold air intakes don't do, so it's more effective from a performance standpoint
Beauty is in the eye of the beholder but I would take a cowl hood over the cold air intake design in the picture for aesthetics any day.
Cold air intakes make sense on an LS/GenV LT conversion IMHO, not carbureted set up.
Are you talking a functioning cowl hood or just the openings?
I'm not saying this is the best idea, but it is what I did.
It was cheap and all factory parts (from some car) in the junk yard. ;)
Engine bay front view by Larry Madsen, on Flickr
Engine bay side view by Larry Madsen, on Flickr
front of core support from side by Larry Madsen, on Flickr
Link to thread: Air intake ... Another silly modification project. | Team Camaro Tech (camaros.net)
My 88 gmc jimmy had the same type of air filter housing,snorkel,and tube that went to radiator core. It worked but I tossed it after I had water come in while wheelin. If y’all go for this type it can be found on 86-89 jimmy/blazer. Perhaps even Silverado’s.?
Concur with Tiley. I added a factory-style ZL-2 ducted hood air cleaner to my '68. It's a simple add, you may have to tweak the air cleaner height with spacer between the air cleaner and carb. Small blocks used a different one than big block cars. For good measure I added the KN top to my setup and blocked off the snorkel to ensure all intake air came from the outside of the car. The engine is a 30 over ZZ502 with EFI. It dropped air temps by better than 10 deg. F.
21 - 33 of 33 Posts
