1 - 20 of 24 Posts
X77Z28MP
69Z survivor
Got my stock DZ back from engine builder had it broken in and dyno'ed ran with sunoco race fuel 110. Do i need to go higher octane or is 110 good, i can get up to 118 what did they recomend for these bad boys THANKS TC
All stock GM parts 11 to 1 compression 30/30 cam,aftm sprimgs ,30 over he ran 110 race fuel on dyno that mouse roared easly up to 7900 rpm and wanted to go higher, That smell of sunoco i will never forget.... :thumbsup:
Gotta love 302s.. 7900rpms.. Hahaha! So what kinda numbers did it put down on the dyno? I would run what ever your builder recommends and then see how it runs on the street. Then adjust accordingly.
The first reading 355 at 7200, adjusted carb 367 at 7300, adj timing 373 at 7300, final run 380 7200,, after 7300 HP fell off But what a roar at 8100
Wow. How often do you think you'd wind it that high on street? I hope this is weekend only with that CR and octane requirement. Octane does not make power in of itself. It allows you to tune for most power while keeping detonation at bay.
I might punch it every now and then but not over 6500 .too much coin into that motor im not rich
I have been running the 110 for 2 years in my 302 and the motor runs very well with it. I have recently moved and cannot easily find it so I am experimenting with 100 AV fuel. It seems ok but I still am going to try to locate the 110.
I run California 91 and MMO. It is built stock and runs just fine. I have 18 initial and 18 mechanical at 2800 RPM. If it is a true 346 adv duration 30-30 use pump premium. If you have a quicker closing intake timing that may change things. Other states have 92 or 93 I think.
Static compression means little. Dynamic compression is most important. A true 30-30 grind puts SC in the low 7s.
I should have said DC not SC.
I wonder what Chevrolet was telling it's buyers to use back when the Z/28's were new. Of course octane ratings changed in the early seventies as well with todays r+m/2 method for 93 octane being equal to about 96 research octane which was the method used in the sixties.
Discussion starter · #17 ·
Anybody out there with info from GM about octane rating for 69Z. It seems the mouse likes higher octane
My 302 has been running since being rebuilt 8 years ago. I used advice from Jerry M. and John Z. That would be a wise thing to do for you. There is nothing magic about these engines. The 30-30 (true to original grind) was a very "sloppy", for a lack of a better word, design using long easy ramps with not very special springs that had a very late intake valve closing angle. Can't build cylinder pressure until the intake valve closes. If you have a "modern" cam that needs high spring pressure because the intake valves snaps shut and builds cylinder pressure fast then you would have to look at things a little closer. Many people that rebuild 302s are frustrated because they want them to perform better so they use a cam that operates differently from the original. Your choice of fuel is up to you. Give Jerry a call and look thru John Z's old posts and get the real info. Also I hope you set up your distributor as John Z advocates to have full time vacuum advance.
Nice HP numbers. Torque readings?
Good luck and have fun!
I would be surprised if GM was not recommending ethyl fuel for the 302 back in '69 which would have to be at least 100 research octane and a few points higher than todays pump premium of 92 or 93. Also lead may have had a benefit to engines beyond just octane and lubrication perhaps? My car seems to run better with it. I was a young teenager in 1969 and do not recall the typical pump octanes of the day. some areas had many choices.
1 - 20 of 24 Posts
