MOOG 67/69 camaro steering and suspension part numbers
MOOG
Both sides outer tie rod 67 ES348R (4.62" long)
Both sides outer tie rod 68-69 ES381RL (5.75" long)
Both sides Inner tie rod 67-69 ES681N
Toe in adjuster sleeve 68-69 ES350S
Upper ball joint K5108 67-69
Lower ball joint K5103 67-69
Upper control arm Shaft kit Moog# K5250 (Offset)
Idler arm + bracket K6099 all 68-69 5.375" long - cast iron, not forged steel.
Idler arm, K6093 all 67 5 3/4" long (no longer available)
Pitman, manual K6150 68-69 (short)
Pitman K6151 PS, short 5.25"
Pitman, PS K6154, 67-69 5.78" long (probably 5 3/4") 32 splines 1.1-1.18 diam. No longer available from Moog.
Pitman, PS , long, Moog# 6582 New production run, no grease fitting - Currently available at any auto parts store that sells Moog parts. These appear to be less durable than grease fitting type, have plastic injected around the stud.
Pitman, PS long, TRW # 18770 Same as above. Probably a Moog part in a TRW box.
NOTE: There are two length pitman arms for power and two lengths for manual. Std 17 to 1 ratio power steering uses 5.25"
Optional fast ratio PS, uses 5.7" long Pitman arm.
Above provided by David, Below provided by a Team Camaro Forum Member.
PART NUMBERS FOR FRONT SUSPENSION/STEERING: 1969 Camaro Z28
Lower Ball Joint: K5103 Federated Chassis
10197 TRW
Upper Ball Joint: K5108 Federated
10195 TRW
A-Arm Adjustment Shims: 1/32" MOOG K961
1/16" MOOG K962
1/8" MOOG K963
Front Coil Springs: TRW CS6312 Constant rate, regular without A/C, Sport Coupe
TRW CS638 With A/C
Same TRW part numbers for High Perf. springs
Control Arm Bushings/Shafts: Upper - K5196 Federated Chassis / MOOG
Lower - K6076 Federated / MOOG
MOOG K5250 [Upper Control Arm Offset Shaft Kit] Problem Solver Kit; Provides Additional Positive Camb er Adjustment; Front Suspension
Idler Arm: K6099 Federated / MOOG
18718 TRW
Chassis Illustration Reference: 01008407MOO Steering Linkage - MOOG
01008301MOO Front Suspension - MOOG
02004601TRW Steering Linkage - TRW
02004701TRW Front Suspension - TRW
Pitman Arm: 18770 TRW w/special steering, w/power steering
Rear Suspension Bushings: B298 TRW Front spring bushing
HB1003 TRW Rear spring bushing - 8 used
Gear Kit, Steering: 2757 Omega - Master Gear Kit, Camaro
2779 Omega - [Gear Kit] Adj. Plug; Camaro List.; Supersedes {2774}
Power Steering Pressure Hose: 564 Omega - [Power Steering Hose] Pres.; OE; Camaro List.
852 Omega - [Power Steering Hose] Pres.; Mod.; Camaro List.
Pwr Steer. Return Hose: 30903 OMEGA [Power Steering Hose] Return; Mod.; Bulk Hose; 25 in. ; Camaro List.
675 OMEGA [Power Steering Hose] Return; OE; Camaro List.
950 OMEGA [Power Steering Hose] Return; Mod.; Bulk Hose; 25 in.; Or {30903}; Camaro List.
Power Steering Pump Kit: 2759 Omega - [Seal Kit] Pump; Camaro List.
Sway Bar Bushing: K5227 FEDERATED CHASSIS [Sway Bar Bushing Kit]
K5227 MOOG [Sway Bar Bushing Kit]
Sway Bar End Links: K6217 MOOG [Sway Bar Link Kit]
Tie-Rod End Adjusting Sleeve: FEDERATED CHASSIS ES350S [Sleeve] Right & Left
MOOG ES350S [Sleeve] Right & Left
Tie-Rod End - Driver Inner: FEDERATED CHASSIS ES681N [Tie Rod End] Driver Side; Inner
MOOG ES681N [Tie Rod End] Driver Side; Inner
TRW ES681N Driver Inner, 1968-70
Tie-Rod End - Driver Outer: FEDERATED CHASSIS ES381RL [Tie Rod End] Driver Side; Outer
MOOG ES381RL [Tie Rod End] Driver Side; Outer
Tie-Rod End - Passenger Inner: FEDERATED CHASSIS ES681N [Tie Rod End] Pass. Side; Inner
MOOG ES681N [Tie Rod End] Pass. Side; Inner
TRW ES681N Passenger Inner, 1968-70
Tie-Rod End - Passenger Outer: FEDERATED CHASSIS ES381RL [Tie Rod End] Pass. Side; Outer
MOOG ES381RL [Tie Rod End] Pass. Side; Outer
Tie-Rod End/Drag Link (at Pitman Arm): TRW ES350S [Tie Rod Adjusting Sleeve] Passenger
TRW ES350S [Tie Rod Adjusting Sleeve] Driver
PART NUMBERS FOR FRONT SUSPENSION/STEERING: 1969 Camaro 350ci
Allignment Front Kit: MOOG K5250 [Offset Shaft Kit] Frt.; Problem Solver; Upper Control Arm Kit w/Bushings; Provides Add. P os. Camber; 2 Req.
MOOG K961 [Custom Shims] Frt.; 1/32 in. Thick
MOOG K962 [Custom Shims] Frt.; 1/16 in. Thick
MOOG K963 [Custom Shims] Frt.; 1/8 in. Thick
Lower Ball Joint: FEDERATED CHASSIS K5103 [Lower Ball Joint]
MOOG K5103 [Lower Ball Joint] Front Suspension; 2 Required
TRW 10197 use two per vehicle; Incl. CUSTOM
Upper Ball Joint: FEDERATED CHASSIS K5108 [Upper Ball Joint]
MOOG K5108 [Upper Ball Joint] Front Suspension; 2 Required
TRW 10195 use two per vehicle; Incl. CUSTOM
Front Coil Springs: MOOG 6312 [Coil Spring] Frt.; HD; w/o A/C; Sport Cpe.
MOOG 638 [Coil Spring] Frt.; Conv.; Sport Cpe. (A/C)
MOOG 638 [Coil Spring] Frt.; HD; A/C; Sport Cpe.
MOOG 6312 [Coil Spring] Frt.; w/o A/C; Sport Cpe.
TRW CS6312 [Coil Springs] Front; Constant Rate; Regular; w/o A.C.; Sport Coupe
TRW CS638 [Coil Springs] Front; Constant Rate; Regular; w/A.C.; Sport Coupe
Front Heavy Duty/Perf. Coil Springs: TRW CS6312 [Coil Springs] Front; Constant Rate; Heavy Duty; w/o A.C.; Sport Coupe
TRW CS638 [Coil Springs] Front; Constant Rate; Heavy Duty; w/o A.C.; Sport Coupe
Connecting Tie-Rods: MOOG ES381RL [Outer Tie Rod End] Front Suspension; 2 Required
MOOG ES681N [Inner Tie Rod End] Front Suspension; 2 Required
Control Arm Bushings/Shafts: SAME AS Z28
Idler Arm: MOOG K6099 [Idler Arm] Front Suspension; 1 Required
TRW 18718 [Idler Arm]
Chassis Illustration Reference: SAME AS Z28
Leaf Springs: MOOG K6559 [Leaf Spring Bushings] Rear Suspension; Bushing Location Shackle
MOOG SB298 [Leaf Spring Bushings] Rear Suspension; Bushing Location Front
Pitman Arm: MOOG K6150 [Pitman Arm] Front Suspension; Manual Steering; 1 Required
MOOG K6582 [Pitman Arm] Front Suspension; Power Steering; 1 Required; 5.78" Between Center of Stud & Center of Spine.
TRW 18768 Manual Steering Exc. 302 Engine
TRW 18770 Power Steering (w/ 5.78" Stud Center to Spline Center) 1968-69, All 1967
Rear Suspension Bushings: SAME AS Z28
Steering Gear Kit: BCA/NATIONAL PSK-1 [Oil Seal Kit] RWD Power Steering; (Kit)
OMEGA 2757 [Gear Kit] Mstr.
OMEGA 2779 [Gear Kit] Adj. Plug; Supersedes {2774}
67 Tie rod end ES348R driver and pass side Outer.
PART NUMBERS FOR FRONT SUSPENSION/STEERING: 1969 Camaro 396ci - Only Changes from Z28 and SmallBlock
Front Coil Springs: MOOG 638 [Coil Spring] Frt.; w/o A/C; Sport Cpe.
TRW CS638 [Coil Springs] Front; Constant Rate; Regular; w/o A.C.; Sport Coupe
Control Arm Bushing Kit: FEDERATED CHASSIS K5196 [Control Arm Bushing Kit] Upper; 2 Required *
FEDERATED CHASSIS K6076 [Lower Control Arm Bushing Kit] Lower; 2 Required *
MOOG K5196 [Upper Control Arm Bushing Kit] Front Suspension; 2 Required *
MOOG K5250 [Upper Control Arm Offset Shaft Kit] Problem Solver Kit; Provides Additional Positive Camb er Adjustment; Front Suspension; 2 Required *
MOOG K6076 [Lower Control Arm Bushing Kit] Front Suspension; 2 Required *
TRW 12162 4 Used, Upper Arm *
TRW 12237 Front, Lower Arm *
TRW 12258 Rear, Lower Arm
Control Arm Shaft Kit: TRW 13158A Upper Shaft Kit, use two per vehicle
Pitman Arm: MOOG K6150 [Pitman Arm] Front Suspension; Manual Steering; 1 Required *
MOOG K6582 [Pitman Arm] Front Suspension; Power Steering; 1 Required; 5.78" Between Center of Stud & Center of Spine. *
TRW 18768 Manual Steering Exc. 302 Engine *
Sway Bar Link Kit: MOOG K6217 [Sway Bar Link Kit] Front Suspension; 2 Required *
TRW 18060 [Sway Bar Link Kit] Standard, use two per vehicle *
TRW 18203 [Sway Bar Link Kit] Heavy Duty, use two per vehicle
