I'm interested in lowering the front end of my 69 sport coupe by about 2". I'd also like to replace the drums with disc brakes. Which is the better way to go: Drop spindles or different springs?
If you were to cut the factory springs down, that statement would be true, but with performance springs, they are engineered to have an over-all shorter length and thus less travel, but are more 'structured' or stiffer throughout that range of travel. This means that you would be more likely to "bottom-out" a factory spring than a lower, yet stiffer, performance spring. And by stiffer that doesn't mean a harsh ride, just more stable. There is a little more thought put into the design process of lowered springs than just 'chopping' them.Originally posted by dawg:
[QB] shorter springs = bottoming out on rough stuff.
Dropped spindles are the way to go and safer.
Gee so thats the reason for dropped spindles!
youll retain full travel of the springs.
and you wont encounter alignment issues as with chopped springs.
[QB]
