What I have is a '91 GM Mark IV 454 crate engine. Less than 300 miles on it. Edelbrock Torquer intake, Holley 750 vacuum secondary carb (model 4160), stock everything else. It has oval port heads.
I don't know what hp this engine was rated at. The engine sounds really good. Little bit of a lope at idle. When driving the car, there is no power. Can only spin the tires in 1st gear (TH350 tranny). If you backpedal to get it to hook, it will dog out after it hooks up. Never has any power in 2nd or 3rd gear. I mean this thing is really slow. I could beat it with a stock chevy pickup!
It was fouling spark plugs big time (within 20 miles they would be fouled). The carb was used in a different car before and was jetted way too big, it had #77 jets in it. I rejetted it to #66's. Doesn't foul the plugs as quick now but still might be a little rich. I am reluctant to go any leaner because I wouldn't think they would need to go leaner than that.
Timing is set at 12 deg. initial. The distributor is an HEI from a sb 350. Tried advancing a few degrees and retarding it a few. Only made it worse. Do I need to recurve it? If so, what do I need to buy? springs, ect?
I don't have a tach, but at about 3000 rpm, the engine will miss fire badly. When revving up through the range, it will struggle to get beyond that rpm, then will get a little better above it.
I was using an edelbrock 600cfm carb. The car was even worse with that. I found that there was a vacuum leak in the edel. carb. The Holley was a known good pulled from a car that ran well (just liked a LOT of fuel, thats why the #77 jets).
I put new plugs in, new plug wires, new dist. cap,
Could a bad tranny cause any of this? How would I tell? Sorry for the long post, but I'm getting really frustrated with this one.
