1 - 8 of 8 Posts
Black69
Can anyone tell me how to remove the window sweeps off a 69 Coupe. I need to replace some rollers and can't tell for sure how the seeps are attached.. Any info will help. Thanks in advance.
You talking about the outer fuzzies? there is a small flat phillips head screw buried in the fuzzy in the front and rear (roll down the window). Then there are clips that hold it on to the door, you kinda pull up and to the inside at the same time (the clips have a slight curve). The clips have points that dig into the metal, so you have to pull pretty strongly (make sure the screws are out 1st! :))
I tried to find any screws but was unable to locate them. About how far from the edge are they? The felt or fuzzy is thick and does not move so I wondering if mine have the screws. I could see a portion of what appeared to be a clip under the outmost edge.
Great, thank you so much for your help, it is very much appreciated!
Turns out there were no screws and they were on super tight. I needed to remove the window to replace the bottom roller on the front lower potion of the window. Unfortunately I bent the fuzzy so I guess new ones will be on order. Thanks again for the help.
1 - 8 of 8 Posts
