Hello fellow camaro drivers,
This is my problem
When the car is cold, it turns on right away, I can turn the car off and on as many times as I want without a problem, once it warms up and you take it for a drive you feel hesitation when accelerating a few blocks, then it goes away and it response perfectly, once you get to an area whether is close or far and you turn off the car, it's hard to get the engine to turn, you have to step on the gas a few times to get it to turn. Meanwhile there still no more hesitation, drives perfect. So let's say I drive a mile or two more after that and try to turn the car on again. It's even harder, you have to pump gas twice as long as the first time. The more you drive it and the more times you turn off then the harder until impossible to turn back on. You need to let it sit for a few hours so you can turn it back on and the vicious cycle begins again. Any ideas?
Car info:
350 Chevy small block
Edelbrock Carburetor
Aluminum IntakeHeaders
Aluminum Radiator
Power Steering/Brakes
This is my problem
Car info:
Aluminum Radiator
