1 - 7 of 7 Posts
Indy Z11
I bought new pre-bent transmission fluid lines for my 69. Fittings on radiator side are no problem. Got the fittings on the transmission side started with my fingers but can't get a wrench up there since the space is so tight. Does anyone know where I can get some kind of long open end 90 degree elbow wrench that will reach up there? Just can't get them tight with a straight wrench.
Pull the distributor, remove the cross member and drive shaft. Let the tail shaft of the transmission down as far as you can before the dipstick tube and other stuff start to contact the firewall. You should be able to get your wrenches in there. Be sure you use two wrenches - one for the fitting and the other for the adaptor. Otherwise you are likely to twist the lines. This is more of a problem upon removal than installation but still an important step to prevent
As for tools, I used flare wrenches which you should use for those types of fittings. But even then I had to use a standard open end wrench because the fitting seems to end up in positions where it is impossible to get the flare wrench on. Just be careful with open end wrenches as they'll round off your new fittings in nothing flat. Oh, and you only need to turn them about 1 flat or 60* once the flare makes contact with the adapter. Better too loose than too tight.
Sometimes crows feet wrenches will help, but I usually find standard wrenches work best. The problem with crows feet are when you get your socket extension etc on there isn't room to turn em.
I had a leak on the radiator side and nothing seemed to tighten it down, even after cleaning it, buffing it etc. My buddy mechanic they put a small dab of axle grease on the smooth surface that makes the seal. Then he tightened it down gently and it never leaked again. Just a hint. A little dab will do ya
Ditto on Don's pictures - use a breaker bar instead of a ratchet to give you a little more clearance. You may have to flip flop the crows foot flare nut from one side to the other to get on the flats of the tube nut.
An ordinary crow's foot would work too. Might be easier to find one at your local Sears.
Never seen a line wrench type crows foot before . . . hmmmm.
1 - 7 of 7 Posts
