I have recently aquired a 1968 327 4 speed camaro.....
I have searched high and low over the past few days and really thie info I am looking of is not really here....
Here is what I know about my Motorn I know it has "Wedge" heads, Either 040s or 041s, suposedly ported, suposedly .500 lift cam (says its a 292 comp cam), forged pistons, pink rods, and forged crank.
It sat for about 12 years before a buddie bought it, and now it is mine, The reason I think the top end needs redone is that it seems that the valve seals are leaking, not bad when it runs all the time but when it sits for a while it gets a prety good puff for the first few times you start it and 3, 2, and 5 show oil fouling on the plugs.....
My question is, what is a good cam for this motor (4.11 rear) and are these heads good enough to spend the cash to recondition or should I look at aftermarkets, This is not a daily driver....I am looking for lumpy and a screamer, I know these are know to rev, I love the sound of a SBC at 6K+
any thoughts?
If I have Pull the moter I may as well look at bearings and all but, the assumption right now is good, (60 psi 25 at idle)
Thanks all!
EMC
any thoughts?
Thanks all!
EMC
