Ok, my air compressor is DOA (anyone want to buy a craftsman 25g 4.5hp compressor with a bad tank?). So it is time for a new one. Yes, I have read many posts here, at Team Chevelle, Autobody101, and Hotrodders.com. I don’t yet own a paint gun, since I don’t know how to paint. But I plan on learning. I also like my die grinder and my sandblasting cabinet (although I’d like a bigger one). Those are big air tools, so I know I need a decent compressor. As much as I’d like to cap it at $500, I’m ok with up to around $900. No matter what I spend, it is killing my budget. So here is what I think I need/would like:
12-15 SCFM @ 40 PSI – sounds like HVLP guns need air
15+ SCFM @ 90 PSI - blasting
I have a 60 amp sub box in the garage, so I should be covered there; I just need to add a 220 circuit. From what I have read, a 60G tank should suffice, but finding those specs on a 60g tank is not easy, so I guess I might end up with an 80g tank. I don’t know duty cycle on any of them.
Here are the ones I am looking at.
• Kobalt / Lowe’s M#K7060HFV
PRICE: $500, SHIPPING: NO
MAX PSI: 135, TANK: 60G, STAGES: 1
SCFM: PSI/40: 15.0, PSI/90: 13.3
PUMP: CAST IRON, RPM: 3450
Link: site not worth looking at
They used to have an 80G that a lot of people liked, but it is discontinued. This will work for me and the stats are good considering the price point. But I bet this SOB is loud.
• Delta at Sam’s Club DLKC6580V (maybeV2)
PRICE: $785, SHIPPING: NO, MAX PSI: 175
TANK: 80G, STAGES: 2
SCFM: PSI/40: 16.9, PSI/90: 16
PUMP: Alum w/Iron Sleeves, RPM: ??
Link: http://www.porter-cable.com/index.asp?e=547&p=5507
I cannot find any specs online about this one, this PC looks close (the delta site took me the the PC site). I got these numbers off the labels. But I couldn’t see the motor (it is on a middle shelf – I didn’t climb that high). This is choice “A” right now due to price & solid stats. The higher PSI should let my blast longer w/o the comp running.
• Eaton Compressor 4.5 HP, 3 Cylinder
PRICE: 850 PLUS SHIPPING
MAX PSI: 135, TANK: 60G, STAGES: 2
SCXFM: PSI/40: ?, PSI/90: 14
PUMP: CAST IRON, RPM: 1050
Link: http://www.eatoncompressor.com/catalog/item/504747/172983.htm
I honestly have not called them, but with shipping this one really seems to blow my budget – forget the bigger ones. But people rave about them.
I looked at lots of other places/brands, but I narrowed it to these due to price (Quincy) and stats (husky, sears, etc.), especially apparently misleading ones like ACFM (many brand use this – tank assisted CFM)
Opinions?
Opinions?
