I have a 400 SBC in a 68 camaro. The tranny is a 350 turbo with a 3000 stall. With 355 gears in the rear... The cam spec's I have now are quite large and are listed below. Can you guys suggest a solid roller cam that would be "ok" on the street? I am also looking at the 4/7 swap for this cam. I plan on just swapping the cam and springs and keep the lifters since they only have maybe 100miles on them....
SPEC CARD
PART #: 12-000-9
GRIND #: CS 319R-1/324R-4 R107
J. DIAM: STD INT EXH
VALVE ADJUSTMENT .026 .026
GROSS VALVE LIFT .601 .634
DURATION @ .020
TAPPET LIFT 320 324
VALVE TIMING OPEN CLOSE
@ .050 INT 33 67
EXH 70 36
SPECS FOR CAM INST. @ 107.0 CENTERLINE
INT EXH
DURATION @ .050 280.00 287.00
LOBE LIFT .401 .423
LOBE SEPARATION 107.0
ROCKER ARM RATIO 1.50 1.50
SPEC CARD
PART #: 12-000-9
DURATION @ .020
TAPPET LIFT 320 324
@ .050 INT 33 67
EXH 70 36
INT EXH
LOBE LIFT .401 .423
