1 - 10 of 10 Posts
Green RS
I'm going to purchase a set of Rally Wheels for the '69 from Ground Up. I need to know which set will fit my existing tires.
Tire size: P235/60R15
Which will fit this tire?
http://www.ss396.com/mm5/merchant.m...ROD&Store_Code=camaro6769&Product_Code=NRK-157&Category_Code=TIRESCOMPLETEWHEEL
or this
http://www.ss396.com/mm5/merchant.m...ROD&Store_Code=camaro6769&Product_Code=NRK-158&Category_Code=TIRESCOMPLETEWHEEL
Or, if I decide to go with the Torque Thrust wheel, which size should I purchase?
I just bought a set of rally wheels this past summer.I bought the
15x7 with 4.50 back spacing.I put P 235x15x60 on the front and I put
P275x15x60 on the rear(see my signiture picture profile) This combo fits
perfect!!! No rubbing at all.
THIS IS MY STORY AND I'M STICKING TO IT....
__________________________________________________________
Hope this helps
Dan
my ralley wheels are 15x7 with 4.5 backspacing all the way around.
My opinion is @ stock ride height you need the 4.5 backspacing with this wide of a tire in the front.
The tire is very close to rubbing with 4.5 bs
235/60-15 tires are 26"dia.and the 275/60-15 are 28"dia.and about
1"wider. But it fits great,with no rubbing@ stock height.
I got my rally's at NPD
Hope this helps
_____________________________________________-
Dan
I would think with the tire size your going with 235/60/15 that it would look better on the 15x7 rim. Putting it on a 15x8 might not give you the right side profile. I'm running a 255 on a 15x8 and looks pretty good. Just my opinion
Discussion starter · #8 ·
Perfect, thanks...
I have 15x8 rally's on the car now (with P235/60R15 tires). If I go to a 15x7, does this mean less rubbing than what I get now (which is little to none) and would it change the hieght of the car?
Sorry, just learning about tires and rims while thinking of buying some new wheels :)
I have 2 sets of rallys, 1 sets of tires has 15x8 rims and the other has 15x7 rims and they both have p235/60R-15 tires on them.The set with the 15x7" rims the tire is 1/2"smaller (narrower) than the 15x8"rim. So that means you will get 1/4" more clearence with the 1 inch difference in rim wight.
Now remember that is with not changing the back spacing!!!
Now as far as changing the body height,this will not change.I went and I check this out for you, the two set of tires are the same in height
Hope this helps
Dan
I believe the 4.25" backspacing is the most common. I just installed a set of 15 x 7 with 4.25" backspacing from Wheel Vintiques. I used P235/60 15 Indy Firehawks and have no clearance problems. You are lucky you have the tires. P235/60 15 is a hard size to find right now - no TAs to be found.
1 - 10 of 10 Posts
