1 - 4 of 4 Posts
84camaroinprogress
67 327 flat tops, stock crank and rods, 601 55cc 305 heads intake gasket matched, 1.84 int 1.5 exh valves, 1.5 rockers stock, performer rpm, holley 650 vc sec, headman open headers, hei accel ingnition, dbl roller timing chain, speed pro cs1062r cam, .468 int .480 exh 220/231 at .050 304/287 adv duration 11to 1 comp. what do u think my hp level is close to now i dont have a clue am i even in the 300 range or high 200 and what about tq take a guess goin to do a dyno soon gota change my tcase first doin it at www.racepartsdirect.com for 50 buxs then changin to a solid cam and tryin again to see the gains
Stock flat top at the crank 300 hp ,or 11 to 1 's 350 hp at the crank.Whats a t case transfer case 4x4 ?? I assume 250 flat top 300 with 11to1 at the wheels...my guess let me know if i am close post later ...have a good one and Happy Motoring
yea its an 83 fullsize pickup motor use to be in my 84 camaro but in the winter time theres more mud than there is drag strip haha so its in my truck and im building a 383 for my camaro, may take some time to get it done because im also doin body work and paint job. the pistons are stock but with the 305 heads i was told i am around 10.5 to 11 to 1 compression and boy it sure sounds like it to cause when im in the mud and rappin at 6500rpm it sure sounds good. might be a month before i can get it in the dyno got to get all the mud off it so none of it falls on the rollers in the dyno plus have to put small tires on it to get it in the door
Got ya now kinda misunderstood,and will bump up my estimate to 375 hp at the wheels ,6500 yah bet it sounds good...Have fun and always Happy Motoring
1 - 4 of 4 Posts
