When upgrading the brake system on a Gen 1, what is the best donor vehicle to get a combination valve from?
By combination valve, I mean one with these functions:
1. Metering Valve, to compensate for rear drum slop time.
2. Pressure switch. To indicate if front or rear MC has failed.
3. Proportioning Valve. To limit the pressure to the rear brakes to stop them from locking.
It would also be great if the proportioning valve was adjustable, but I don't think factory units are.
The plan is to mount it right next to the Master cylinder
One alternative is to use a valve without a proportioning valve. In stead I would add an external proportioning valve But this would mean I would need a valve which only has the metering and pressure switch functions. Any suggestions?
