1 - 8 of 8 Posts
Fred Mertz
Discussion starter · #1 · (Edited)
I've decided to just rebuild my original 350. I thought I would go with a stock rebuild on the short block. It's an L-65 255hp.
I want to go with new alum. heads. I'm looking at the 180cc runner ones. I like what AFR and Dart has to offer. I will being going from a cast iron 76cc head to a 64cc alum. head in order to gain some compression.
I will use an Air-Gap RPM manifold with a 650cfm vac. sec. Holley.
Cam will be in the 270deg. with less than .500 lift
This is just a street cruiser so don't think I would benefit from bigger heads.
Any opinions or suggestions on my ideas would be appreciated.
Thanks;)
AFR's cheaper than Darts Pro-1's and better flow #'s. Now if your looking to make it a sleeper with a set of iron heads then I say Darts "Iron Eagle" heads.
I see AFR heads being sold online but never see "Eliminator" mentioned in the description.
Also not mentioned in Summit or Jeg's catalog.
Something special?
1 - 8 of 8 Posts
