1 - 5 of 5 Posts
Chevy-SS
I am using CE J-bolt traction bars, but am using standard u-bolts in place of the j-bolts (which I never liked).
Anyway, these CE bars are big, ugly (see pic) and heavy. I would love to get a set of lighter aluminum bars to reduce unsprung weight and improve appearance.
Any suggestions?
thanks
I have the same type of traction bars you have.
I cut off the front section,installed box aluminum (1/4" wall thickness)tubing inside the exsisting steel tubing.Tried them out & they bent first time I launched pretty hard w/a 4 spd 4:10 rear gears & street radials.
I bought some smaller box tubing made of steel slid inside the existing steel box tubing & used a couple of large bolts,works fine & gave me a little more ground clearance towards the front.
MBHD
Steve, thanks for the link to the bars - those Lakewood bars (in pic below) look pretty nice. Very lightweight, I'll bet. Not sure how they would affect ride quality, bolting onto the springs like they do....................
1 - 5 of 5 Posts
