Okay, what did I miss? I picked up a dipstick guide tube for my 400sbc and it does not fit. The diameter of the tube and the diameter of the location are the same. What did I miss???
This is an interference fit, will have to be driven into block using the lower bulge lip as a ledge. Open end wrench will help . Easy if motor is out of car, If not, A piece of maybe 3/8" pipe with a lengthwise half moon cut could serve as a driver.Yes. That was the first thing I looked at....no part still there
Thinking outside the square..coolI have no idea if this would work, but how about throwing it in the freezer
Ah ah... yep always works better after a soccer practice...worth a shotGoing to try the freezer idea after soccer practice tonight.
