I have new disc brakes on the front and the stock old on the rear. I have a new power booster that came with the front brakes. I have bled all lines in proper order. The brake pedal is very mushy and even more mushy when the car is running. The brake pedal will stop the wheels from turning when rotation them by hand. What are the symptoms of the proportioning valve issue? Maybe I
have to reset? I have a reset button that I did press back in. I cracked the lines when applying pedal pressure to get air out of master cylinder. I may have to do this again as I found some drips and so I tightened up those brake lines. The vacuum line to the Powerglide modulator is in place, but the vacuum tube does not inset more that 5mm. I can't test the vacuum because I can't drive the car without brakes. What do you think? Thanks.
