1967 camaro over heating when driving down the road
3.2K views 48 replies 16 participants last post by  bella2024
my 1967 Camaro is overheating it creeps op to 220 degrees it stayed at 180-190 then i changed the schrod old one was broken the new schrod seems to be closer to the motor the fan is completely inside the schrod could that be the problem?
Maybe post pics of the two shrouds.
Post a pic of the shroud installed in the car
Reactions: srode
If it is overheating while moving at a reasonable pace this is indicative of inadequate flow or an undersized radiator. Shroud & fan are for low speed and idling conditions.
When is the last time you changed the thermostat? Are you sure all air is out of the system? Belt tight on pump and not slipping?
#39 ·
Maybe I'm wrong but that water pump doesn't look like its new, seems to be a cast iron one that has been sitting around for a while, it looks rusted. Your radiator.........looks like a aluminum one and you mention its a 3 core with 1" tubes. Is this correct?
#11 ·
That doesn't look like a Camaro shroud.. reminds me of one off a Monte Carlo or Chevelle
Looks like the NOS one for a Camaro I have in stock, GM part #3893812 and the original one on my car and the other ones I've seen.
#21 ·
Since you have a long waterpump I would probably try a 69 Camaro fan shroud.
#22 ·
Scrod. Past tense of screwed. Or catch of the day.
I doubt fan depth is the problem. I run the same shroud, original clutch fan, Prestone 50%, short Edelbrock water pump, healthy radiator and it never, ever gets hot idling or at 80+ mph. How are your water pump and radiator? How does your coolant look?
#24 ·
Also, the shroud does not envelop the entire area of the core. All components must work as a cooperative system to cool efficiently. And can be done without thowing electric fans at it like so many think is the best thing on the planet for every application.
#34 ·
The info provided is confusing.
initially my understanding was the only change the OP made from the car running cool to overheating was replacing the broken shroud. And the new one extended almost to the engine.
obvious to me if this was the only thing changed it caused the issue.
if other things were changed in addition to the shroud then it’s anybody’s guess to the overheating.
#35 ·
It doesn't look like it has a/c from what I can see. But sealing the gap between the core support and the radiator will improve cooling air going through the radiator and fan.
If it an a/c car, let us know. More tips will be given'
#36 ·
Bella2024 said the problem is going down the road, that has nothing to do with the shroud. The shroud is not wide enough to cover the entire radiator from the picture. While that won't cause any problems going down the highway sitting at an idle or slow moving traffic it will because the fan won't pull through that area of the radiator. The fan position inside the shroud and the depth etc won't have any impact on the cooling going down the road at any significant speed, the fan isn't pulling any faster than the air is blowing through the radiator. It's clutched so it won't impede the flow either. There is something else causing the temperature creep going down the road IMHO.
#37 ·
Post number 5 says it also overheats idling. Pay attention Steve! :p
  • Haha
Reactions: srode
