I am replacing the old motors with this style upgrade: Ecklers Headlight Door Motors,Rally Sport (RS),1967 while I am at it I got a new relay board, bushings, new limit switches, and new arm that connects to the motor.
Everything was going well cleaning up mine and disassembling and reassembling. I just pulled the plate off that holds the motor to the headlight assembly and tried to install the new upgraded motor/plate and the holes just don't line up. I put in the pivot bolt first and when I try to get the other holes to line up the cast motor body portion pushes on the headlight adjuster spring and will not allow the holes to line up. I'm sure its something simple but any idea what am I missing here!?
