1969 427 ZL1 standard bore 4.25 NOS counter exchange block never run casting #3946052 dated 3-1-69 with no stamp on the deck and stamping down on the bottom side of the block by the oil filter of T 08 0. 3946074 aluminum heads dated 8-22-70 & 10-1-70. 3933198 intake dated 8-10-70. 4296 holley carb dated 893. 7115 standard steel crank with 7/16 dimple rods and TRW factory replacement pistons. I also have the factory aluminum water pump. Internals are balanced and block is ready to be put together. Asking $35,000 or best offer and will consider separating the parts out and selling as a shortblock.
1968-69 ZL1 tall deck standard bore 4.40 block casting number 3946052. Block was pressure tested and is a good rebuildable core with date on backside of 06017. $8,000
Can ship if you cannot pick up. I can be reached at 330-770-2517 for any questions or pictures needed.
