I recently purchased a 1997 z28 camaro 30th aniversary ed. i was wondering if anyone knew what type of gears it has in it? if it has posi-trac or limited slip? and what is the best way to get maximum performance with out breaking the bank?
It's got an LT1 engine cast iron block alum with reverse flow cooling and an opti spark up front instead of a dist. It's responds to all the typical mods, heads, cams, headers and of course the odbII is programable. Your rear gears if memory serves me would most likely be 3:23:1 and it should be a posi which is limited slip by the way. There were other gear options and the stick and auto got different gears stock I believe...
gears are 3.42's for 6 speeds and 3.23's for autos. Don't wanna break the bank then go with a good intake (slp makes a good one), headers, and a catback. I suggest magnaflow. They have a new one that sounds excellent! Deep, crisp tone and it purrs at idle. If that isn't good enough come back
If it's an A4 tranny the gears could either be 2:73's, 3:08's or 3:23's from the factory. If someone has changed gears in an A4 more than likely they are 3:73's. If it's an M6 they are 3:42's from the factory but again if someone has changed gears they are probably 4:10's. Performance again depends on tranny. A4 best bang for the buck would be a stall converter. Go to www.ls1tech.com alot of LT1 info on that site also.
Related Threads
Team Camaro Tech
posts
2.4M
members
90K
Since
1998
