I was gifted a 4 barrel intake, and a quadrajet, so I plan on swapping it in. Just wanted to hear from anyone that did so, if there were any good lessons learned that I haven't foreseen.
It's a stock 69 307 Camaro and the carb is from an 84 K10 with a 305. However, looking at the stamping of the Quadrajet, it appears to originally be from a 77 C10 with a 350 (if I read it right). I'll attach a picture of the stamping, and would be appreciative if I read it wrong and someone else catches it.
I have new manifold gaskets for the intake, coolant line and distributor. I can adapt the fuel line with some rubber hose for now. I have an air cleaner to throw on it. I also have the liquid gasket to cover the timing cover gaps. Looking for someone to hopefully point out it there are any glaring peripherals that I'm forgetting before I get everything torn apart, and find out the hard way.
There do seem to be more vacuum lines though, so I'm not sure if I should just cap them. I assume that's just because it came off of a newer vehicle. Also it's an electric choke, and the original was thermally controlled. Is it as simple as running power to the electric choke? Or is there more to it?
Thanks for the help. This car is my first dive into carburetors, so I appreciate the wisdom 😅
