Legrand,
Your post reads like you're standing in my garage looking at my 332 that's on the engine stand. It's a small journal with 12.15:1 forged TRWs, -140 off road cam, Smokey Ram cross ram, ported 461 heads. Hedman Husler big tube headers and Accel dual point with tach drive. Next to that sits a box of brand new 302 forged pistons I just got from Smokey Yunick Estate. I'm thinking about getting the 283 crank and doing the same as you are.
Here's what I would do with your 301. Definitely run more cam than the stock cam. I like the -140 off road cam because it has so much overlap with your 12:1 set up it won't detonate nearly as much as the stock cam in an 11:1 motor. It pulls much harder and sounds incredible compared to the stock 302 cam. I wouldn't run the edge orrifice lifters unless you are running roller rockers. They reduce the oil flow to the valvetrain and I think you'll want all you can get with the stamped steel rockers. Consider going with 1.6 rockers as well. I've done this and it results in .539" lift and .123" valve to piston clearance with the .380" dome GM forged pistons. Good choice to go with a chrome moly pushrod. Anytime you run higher compression it aggravates pushrod breakage especially on the exhaust side due to the valve timing.
ARP rods bolts are a must and I assume since you've got a small journal you bought the pro series wave locks. They're much stronger than the standard ARP wave locks and I think it's all they offer for the small journal. Your Corvette rods are the only concern. I run the 67 small journal rods and I know its the weak link in the motor. I'd like a good set of Eagle H beams. Check your rods at the big end. If the flange at the crank bore has a perfectly round lip to it, I'd look for some 327 small journal rods. They have extra material and you'll see the differnce with two humps at the flange line. These are stronger than the 283 rods and are the strongest small journal rods made by Chevy. I know a lot of guys that ran the 283 rods and had problems in the 301 because of it's high rpm potential. Crane makes a single spring with a damper that fits in the stock spring pockets without maching and is good to .580 lift. Your dual springs should work fine, just make sure you don't have to have the spring pockets machined. Make sure when they machine your heads for the screw in studs they remove enough material to run guideplates under them. The book "How to Hotrod SBCs" lists what needs to be milled off for screw in studs with and without guideplates, but the dimension is wrong. I milled mine myself and ended up needing to change my pushrod length to correct my geometry problems. I don't know whose screw in studs you are using, but they are all different dimensions and lengths and throw off the milling needed. ARP I have found to be the best overall for strength and how they are designed.
Here's what I learned about screw in studs, nobody talks about the differences, but they are significant and will really effect things. Length bottom of base hex to top of stud GM=1.59", Summit= 1.74", Dorman=1.75", ARP=1.75", bottom of base to start of threads GM=.806", Summit=.960", Dorman= .949", ARP=.952", hex base bottom to top of radius on top of base (interference with rockers limits area) GM=.281", Summit=.352", Dorman=.419", ARP= .395", base thickness GM=.231", Summit=.219", Dorman=.296", ARP=.211". ARP ranks #1 for clearance in the first and last dimension, GM ranks best for clearance in the second and third. I choose ARP for strength and the fact the studs come machined already for posi locks nuts.
Your 780 Holley will work fine, I'd go with a mechanical secondary. Use deep groove pulleys because you are going to find you run a lot more RPM than 6500. All the 302s I've run start making power at 4 grand and pull hard to 7500 or 8. I've never broken one running them to 8000 and above, I can't say that about 350s I've run to 6000.
Good luck, sorry to ramble on. You can email me if you want more info, my profile has my email address in it.
Dave
[This message has been edited by SY1 (edited 12-23-2001).]
