Hey all. So I’m putting together a parts list for my 67 base model (original 4speed car). Right now I have a 383 that’s got a TH350 on it that I’m putting into the car. I’m taking off the TH350 to use the Muncie that’s in the car right now. The Muncie is from 69 (according to the numbers). I still need to take it out of the car to figure out model. Currently the rear end is the stock one and it needs to go. It clunks when the car rolls. I have a newer 8.2 that can go in the car, I still need to figure out the gears in it.
I have the opportunity to get a 12 bolt with posi that’s set up for a first gen. Unknown gears in it. BUT I’m not sure what shape it’s in and it’s around $900.
The 383 has around 450 hp. I plan on driving the car mostly to work (all highway) and around town with the occasional day going down the drag strip a couple times a year at the most, and to take cruises with the wife.
So my questions:
1- rear end- stick with the 8.2 I have and freshen it up or bite the bullet and go over my budget to get the 12 bolt and be done with it. Or would it be better to go with like a new 9” over the 12 bolt I’ll probably have to put new seals and bearings in anyways.
2- flywheel - would a 152 tooth aluminum be ok to run? This is the first time setting up a manual car so I’m learning.
3- clutch - I have my eye on the McLeod street extreme. It’s about what I wanted to pay for a clutch. 340 at jegs. Any reason not to go with it? Something better out there in that price range?
4- where is a good place to educate myself on all the linkage and everything that goes between engine and trans? I want to be sure I don’t miss something when it all goes together.
5- trans- rebuild kits? Is there one that stands apart from the rest and far as quality/performance? Or one that people seem to prefer?
Sorry for all the questions. Just trying to do it right the first time so I can drive this thing! Haha thanks for the help in advance.
So my questions:
