I agree with the above, you would benefit from a good al head in this case. If you can't swig a roller, I would go a different route with the HFT cam, a better grind, and if it were me, I would go with solid. There's not really any downside aside from checking lash, but who doesn't like to tinker on their car every now and then. Bottom end it will idle better, better vacuum over a big hft, and you won't have to worry about lifter pump up when you spin to 6k, and with a 292, you will be spinning to 6k.
