With the clutch, chances are overdriving it would only result in more slippage in the clutch, not more air movement. This would then result in more heat in the clutch (see those fins on it? The are there for a reason). You may have a dying clutch which is slipping too much. The only other way would be to somehow drain the fluid and fill it with something thicker. Or put on an electric fan or flex fan.
Sent from using Tapatalk
