I have a 69 camaro that had a TH350 with a center console. I put a BW Super T-10 in it and cut the hole in the floor in the same location as another 69 that was a factory floor shift. I bought a competition + shifter (part # 391-7438) and the install kit (part # 373-8609). When I tried to bolt the shifter to the mounting plate it is hitting the side of the tunnel and I am still 2" below the holes for the bolts to go into the mounting plate. The top of the mounting plate is only about 1/2" below the tunnel. Tech people from Mr. Gasket said that the shifter and intall kit were as close a match as they show. Is there any remedy for my problem? Also I have 14 x 6 stock ralley wheels and I would like to put some 24560R14 tires on them. Will these tires cause any problem with fender or steering clearance? Thank You For Your Help. David Wright
