This is a platform we build here on the 427's using some of the 496" pistons, with a 1.270" C.H., and a rod length of 6.635" (+.500") conn rod.
It's not an inexpensive build, but it surely works real well ending up with a fairly light piston, which leads to a lighter bobweight for balancing!!
These builds "rev" quickly with the combined "short" stroke and the lightweight components. The extra long rods weigh about the same as a stock 6.135" BB rod, about 800 grams but as I said, the pistons weigh much less!
We do about 3 or 4 per year on the resto's where the 427" stays in the picture!
(Add) An added plus here, with the extra long rods, is the fact the piston stays higher in the bores at BDC. This keeps the piston/ring pack more stable overall.
Thanks, Gary in N.Y.
P.S. The final cylinder head choice really determines where the piston configuration ends up! Need to know head part numbers??
