I have a 509 -400 block with the #'s 010-020 with the # 509 between the 010-020 ,also the#'s 512&532 on the other side of the area plus the number G18.I know about the 509 010 020 400 blocks with the high nickle and tin content.I also just got my hands on a 350 standard bore block,here is my question,the 350 block that I just got has the 010-020 with the 509 in between the 010-020 under the timing chain area,plus the #'s 512 & 532 on the same side as the 400 block plus the # G16,I thought that only the 400 blocks had the 509 #'s on them.There is the #'s on the pad on block,as follows c4u162575 VO320TML .Could someone run these #'s and give me some Idea what kind of 350 that I have and if it is worth building a 383 from,any help would be appreciated,,,,Thanks Camaro BOB
