1 - 1 of 3 Posts
YES!
Here is a picture to help you out. It is the same on both sides. Cut a hole in this location, then you can feel out to how far you can go (cut). After that, push the wire up towards the dash behind the kick panel. You don't have to take anything apart. You can also push a wire through the top of the kick panel down. Sometimes it is easier if you losen a few screws. Remember that the puddy behind the kick panel can hold it pretty tight.
1 - 1 of 3 Posts
