67 RS Original Gear ratio
1 reading
1.6K views 7 replies 7 participants last post by  pdq67
Anyway for me to tell what gears I have in my 67 RS? It is a 327 4spd car.
Look on the front of the passenger axle tube, there should be some stamped numbers there that will decode what gears were in it from the factory. My guess would be 3:08 gears.
Thx to all.
Checking numbers is one way, but someone may have changed the gears. The only real way to know is remove the diff cover, count the teeth on the pinion gear, (middle gear) count the teeth on the ring gear, (big ring). Then divide the ring gear teeth number by the pinion gear teeth number. Your gear ratio will magically appear in your calculator.
