Opinions, should I use one or not? If yes, I will need to order a new one I live in Washington State so may do some limited driving in colder weather.
Everything that r-66 daid and i would like to add . When they were new and worked properly they had thier us somewhat limited but usefull . The problem is if you did not keep them lubricated with the gm or Chrysler heat riser graphite lubricant they rusted up. Now if it rusted open no problem but most times they rusted shut. My solution was remove ith and cut the butterfly and shaft right out then tap and thread where the spring handle was with a 3/8ths 16 tap and then use a short bolt to plug it up now you have a free flowing spacer . I have never had a problem with that here north of Boston. i hals drive my car till it snows. then its garaged til spring and three rain storms to wash the road salt away . takes a bit to warm up but its manageable . AlexIt really boils down to how original you want it to look and if you want it to perform well in cold temperatures without a warm up.
