87 Chevy/67 Camaro restart problem
928 views 4 replies 3 participants last post by  cfauver
How old are the plug wires? was first thing came to mind but you strike me as the kind that woulda changed em if they were iffy.
Then hot start issues are usually carb percolating was second thing came to mind, but you put a new carb.hmmm
So what else changes hot. Anything electrical will change with temperature. Could be losing the distributor. And it could be tight valves. When cold the lifters would not be pumped up but right after a shutdown they would be all pumped. Is it a points distributor or HEI? And have you run the valves yet?
