Alternator Mount Driver's Side
5.1K views 14 replies 7 participants last post by  Go69
This is harder than I thought. I'd like to mount my alternator on the driver's side so I can eventually install Vintage Air compressor on the passenger side. I think I have a long water pump. I bought a bracket that doesn't line up with anything (it's the bracket you use to tension the belt). Can anyone recommend a full kit for me? I need the bracket that mounts to the block (the solid mount that would be the hinge mechanism), and the bracket that mounts to the water pump or intake manifold or something that is used to tension. Here's a picture of the front of my engine.
the pic that mnm99 put up IS the early cast iron version of the vette bracket, and will work for a drivers side alt, short water pump setup.
Note that, by definition, 68 and older small block cars have a short water pump and drivers side alternator and no accessory holes in the heads. 69 and up use a long water pump and pass side alternator and the heads have accessory holes. This goes for ALL chevy passengers cars, probably trucks too.
Exception is Corvette, which used short pump / driver side alt thru 82.
It's not a terribly big deal to switch from one setup to the other, but unless you go with fancy custom street rod style bracketry, it's gonna be ALL or NOTHING.
Here's my pic, "late" vette alluminum bracket, short water pump 68 w/accessory hole heads: http://www.camaros.net/forums/attachment.php?attachmentid=830&d=1148210985
You mentioned Vintage Air? Think now, that ac unit will come with I think , Alan Grove Components brackets. Look to see on their site what they have as a complete set up for the alt (and i know they do). This way all brackets will look alike.
you can tell simply by trying to stick your finger between the pump and the timing cover. With a long pump your finger will fit between them. With a short pump, a peice of cardboard will barely fit.
Note that with a 69 car and oem bracketry, pass side alternator and drivers side A/C is "normal." It's not the only way for sure, but when you order your vintage air it what they will "expect"
I second the notion to do some shopping at Alan Grove and see what they have available. When you get into the custom street rod style stuff, many many combo exist, it's just a question of ordering the right setup and having the $$$ to pay for it.
I totally agree that having those big A/C hoses draping across the front of your moter is ugly as sin, but it becomes a question of how many $$$ it's worth to you to get rid of them.
Cheapest way to do it would be to put on a short pump and the vette alt. bracket, then order the A/C for a 68. Note that if you do it this way, you'll need to research the power steering as well if you use it, 'fraid I don't have the answer there for sure.
Around $30 and for bolts for a shorty.. If it comes down to it.
#15 ·
I am running the factory serp. system off of a 95 Chevrolet pick-up.. It's the same as the 4.3L set up. The bracket that holds the alternator (drivers side) and the power steering pump is all one piece.
I found a way to mount the belt tensioner using one of the water pumps bolts and the system works flawlessly. The alt. sits just high enough that I can get my tall valve covers on & off without having to move it. No complaints on this system as of yet.
