You are correct Kurt. But if an X44 is non-SS, Non Z28, and if it's not a COPO, Baldwin-Motion Car, or Yenko , it does not have any of the following according to Camaro's.org: black body sill, rear qtr moldings, drip rail molding, wheel open moldings, blacked-out tailpan, rally stripe, what does it make it? A base Camaro.
*COPO Camaros were an exception, as most COPOs were built
out of bodies coded with X11 or X44, with some cars built
from X66-coded bodies.
That's what I said above. X44 could have been a COPO. However, it is a well known fact the Baldwin Motion Phase III Camaro was pumping out at least 500 HP or more and the Baldwin-Motion Cars would smoke a Yenko which could have been an X44 as well. Only the ZL1 was faster than Baldwin-Motion's Super Car's. This has been documented in magazines like Super Chevy and others.
It is also a known fact that some 1969 Camaro's with tags such as 12B or 12 C could have had the 327 as a base engine. That was changed in early 1969 when the 327 was eliminated in favor of the 307....see below from Camaros.org.
L14 307ci/200HP V8 2BC - non-SS, 1969 only
LF7 327ci/210HP V8 2BC - non-SS, eliminated during 1969
"Note that X11 and X44 codes also included L26 230ci/130HP-1BC and L22 250ci/155HP-1BC 6-cylinder engine cars, as well as models equipped with the LF7 327ci/210HP-2BC, L14 307ci/200HP-2BC, L65 350ci/250HP-2BC, or LM1 350ci/255HP-4BC engines".
That's what I said above an X44 could have came with a low output 350 such as the 255HP.
It is a well known fact that all SS Camaro's were equipped with from disc brakes for 1969. Everyone has see the X11 car claimed to be a reall SS with front drum brakes.
I know I am not perfect. I know I make mistakes. But in your infinite wisdom please inform me what I said was incorrect.
X11 could have had a 6cyl, a 307, 327, or 350 V8, that does not always make in an SS. X44 could have had the same engine options.
According to camaros.org which is where I read that information prior to you posting it everything I said is correct. BTW, tell me the last time you saw a Baldwin-Motion sticker or decal for sale on e-bay? I'm not trying to be a jerk, I respect your opinion but I did my homework on that info before I posted it. Ok maybe a Baldwin-Motion Car was made out of an X22, X66, X11, X44, X55 or an early Norwood or LA tagged car and I apologize if I'm wrong on that. The Baldwin-Motion Camaro's were also guaranteed to run 11.50...That blows away a Yenko or COPO. Please inform us what I said was wrong.
I know the X-44 has no relationship to the option you mentioned. But once again, if they are non SS, non Big Block, Non-Z28, Non COPO, Non ZL1, non Baldwin-Motion, non- Yenko, no styling trim, what does that make an X-44? a base Camaro either equipped with an inline 6, 350, 327 or 307? and maybe a P/G trans or maybe a THM350 or Muncie 4 speed? If I'm wrong there please let me know.
Here's a website some of you may like on Baldwin-Motion Camaro's built from 1967-1974. The Phase III was da bomb!!
http://www.officialbaldwinmotion.com/history.htm
Thanks for your response, I appreciate it and I stand corrected. Happy New Year!!
Greg
