Automatic, Column to Floor shifter (aftermarket) question
1.9K views 3 replies 2 participants last post by  hazman1969
#1 · (Edited)
I changed out my column shift steering column for a rebuilt floor shift steering column. I have a TH400 transmission and plan on putting an aftermarket floor shifter in the car. My question is (see attachment for detail) what is the purpose of the linkage mechanism that attaches to the subframe and ultimately back to the steering column and transmission? Is is a necessary part that needs to remain (because I don't have one, my car was a project missing many pieces) in order to serve a specific function or can I just install a floor shifter with a cable to the transmission? Thanks for any help, David
I think I answered my own question with more reading, the neutral safety switch is activated by the linkages. I'm still having to get used to looking at the factory assembly manual, it seems to jump around a lot and the lack of table of contents doesn't make it any easier. I'm gonna mark the sections with tabs soon. However, if anyone still has something new to add it would be great. Thanks, David
#3 · (Edited)
Well...actually, that's not exactly correct, but I can see your line of thinking. Whether it was a column or floor shifted automatic, the neutral safety switch was activated by the the shifter lever - but it is all hooked together. If you were to keep the stock shifter and just remove the linkage, your NSS would still work.
The linkage system was there so that you could not shift the trans out of park unless you put the key in the ignition switch and turned it to the "run" (or start) position. I think it's commonly referred to as "ignition interlock" or similar. It was a safety thing. You needed the key to get the thing out of park, and you needed to be in park before you could remove the key. Kept the curtain climbers from playing in the car and taking it out of park, etc. Interferes with lots of header brands, so many are long gone.
To answer your question - if your car was originally a column shifted automatic, without the linkage installed you will lose the function of the NSS that is on top of the coulumn. Your aftermarket shifter should have come with its own NSS and it's a fairly simple process to wire it in. Look for 12ga purple and purple/white tracer wires to your existing switch and extend them to your new switch which will likely be mounted on the shifter body somewhere.
The column shifted automatics had the switch mounted on the column. The floor shifted automatics had the switch mounted on the shifter base. If you swapped from column shift to factory floor shift and kept the interlock linkage intact, you could retain the column mounted NSS and the linkage would activate it. You might be able to do that with your aftermarket shifter provided you can find a trans lever that will accommodate the interlock linkage, but I think most aftermarket shifters are a universal design that probably won't include the correct lever.
Thanks for the detailed reply. I have been doing more reading/research and found similar information but the way you explained it is much better. I layed under car and sure enough the linkages won't fit due to my headers anyway. I'm considering trying something I found made by Lokar...its called a column linkage. Basically, it is a straight rod that attaches to they eye of the steering column and then to the shifter arm mechanism. I plan on posting pics for people if this works out. Thanks again, David
