benefits of msd 6A or 6AL
2 reading
32K views 16 replies 12 participants last post by  69huggero
I am debating on installing an ignition box in my 69 camaro and wondering if I would gain any performance by installing a box, here is my set up:
383 stroker
10:1 compression
afr heads
super comp headers
msd small cap distributor with blaster coil
comp roller cam cs xr276hr-10 .502 int .510 ex/ 224 int 230 ex @ .050
650 holley dp 4150hp
466hp/477ft. lbs dyno at flywheel
rpm air gap intake
th350
3.55 posi rear
any input is appreciated--thank you
To expand on what Dawg stated...
MSD provides a spark for 20 degrees of rotation. At lower rpm, you will get multiple sparks during that 20 degrees. At higher rpm, time becomes an issue, and you won't get multiple sparks during that 20 degrees (the piston is just not there long enough to produce multiple sparks) However, the MSD unit will continue to make sure that it does provide a spark for those 20 degrees, its just one longer lasting spark.
Also remember that the MSD unit will provide a higher current to the spark plug, compared to a traditional system.
So, MDS = better performance over all. Get the AL for the rev limiter.
I suggest you look at Mallory's HyFire VI. It has about every option you require for future needs and is a Multi-Spark Unit.
Has Spark Retard for StartUp below 100 rpm
Rev- Limiters for Main Advance, Optional Retard Unit, NOS and MAP Spectrums ... etc
Mag Trigger Ignitions
Tachometer Calibration.
Will work with Points, MBI, Optic and Magnetic Trigger Ignitions.
Digital Panel Interface
I've been using one for 4 years with the Mallory MBI Distributer and like it.
One other consideration not mentioned, is that with a stock HEI distributor (I know you have the MSD street distributor) that is reved above 4700 RPM, the power running through the ignition module gets it so hot that the transistor inside break down. The inductive ignition system then sputters and drops cylinders at high RPM which looses horsepower to the rear wheels. Run it had enough, long enough, and it will burn up; as it can not shed heat fast enough through the amount of contact area allotted to the stock module. (The factory thinks that the heat conducting white paste is expensive, and never uses enough to get full coverage of the bottom of the module).
You do not have that issue with a capacitive discharge MSD as it works at full power all the time and is designed to shed any heat build up. At low RPM the power is spread out over multiple strokes, but the same power fires a single stroke at high RPM every time with no dropped cylinders (unless it hits the soft rev limiter).
Big Dave
