I know there are a lot of BBC heads. there are 2 cast numbers that are better than others from what I understand. can anyone give me those numbers? I think 1 of them ends in 290. and think the other is 048? Thanks in advance.
I am assuming that by better you mean better flowing.i know there are alot of bbc heads. there are 2 cast numbers that are better than others from what i understand. can anyone give me those numbers. i think 1 of them ends in 290. and think the other is 048? thanks in advance.
I have a 69 camaro with 396/375 block with 990 heads. I'm not sure what can they have in this motor.I am assuming that by better you mean better flowing. I have flowed plenty of factory big block chevy heads, so here it goes. 290 & 049 heads have oval ports. 290s are closed chamber, 049s open chamber. They both flow similar numbers until .400 lift when the 049 head will flow better at higher lifts because of less valve shrouding. This is especially true when 2.19 intake valves are installed. The exhaust is a different story. With either stock or 1.88 valves, they flow identical. There is a compression difference between the two however because of the chamber difference. The same on rectangle port heads. 840s closed, 990s open. They already have the 2.19 intake valve and the 990s flow better at high lift. The exhaust seems different than the oval ports I mentioned earlier. 840s seem to flow better throughout the lift range over the 990s. So which is better? Compression ratio, lift of cam being used, and intended RPM all play a part. If you post what you are building I can steer you in the right direction.
1970 454s were closed chamber.For Iron Oval Port usng Open Chamber Pistons, I would lean toward the: 3993820, 71, oval, OPEN, 402, 113cc chamber, 255/114 ports also found on the 71-84, 454 Passenger and Trucks.
Less Dome equals Best Chamber Ignition, when reaching for your desired Static Compression.
396's and 427's were Closed Chamber (Not talking about the 366T or 427T Mills which were Open Chamber and mainly Peanut Ports) - It was the 70 454 that introduced Open Chamber to Passenger Cars and the 402 (+.030" 396) went Open Chamber in 71. About the only exceptions were the 265Hp 69 396 112cc Open Chamber 3933148 Casting and the 3975950, 68-70, oval, OPEN, 396, 402 Truck, 366T, 427T Castings.
The 820/113cc, 781/118cc & 049/122cc chambers all Port Flow approx the same and Noted as the Best Flowing Large Oval Ports. Chamber Displacement are know to vary - So you have to CC anyway.
That's my understanding for MKIV Closed Vs Open Chamber Oval Port Iron Castings.
As long as you do the bowl work to match the larger valves also. My experience with the 063 or 290's i mentioned earlier usually flow 290-300 in. 200-210 ex. @ .600 lift with the 2.19/1.88 valves and bowl work. There's more in them but the short-turn needs work. Not hard, just takes more time. Personally, I always put bigger valves in the passenger car heads. With such easy work it's just a shame to leave that airflow gain untapped in my opinion.
That will certainly take a different balancer but you probably already know that.what about a 496 dressed to look like a 396 in a 69 camaro, want the look of a 396/325 using the right cast manifold and quadrajet carb.
Oh Yah, the 290 Oval with either the Large or Small HEX Plug where CLOSED Chamber on 70 454's but there where also OPEN Chambered 6272292 Casting used on the 70 402 and 454. I was attempting to point out when Large Oval Port OPEN Chamber came on the scene and more or less became the norm. with my Statement:1970 454s were closed chamber.
I know the 330864 and 865.....68-84 Castings where OPEN designated by Mortec for 396, 402, 366T, 427T, 454 Truck but I believe they are Peanut Port or not much better for Air Flow - I could be wrong.It was the 70 454 that introduced Open Chamber to Passenger Cars
It's not that the Combustion Chamber is inferior it's that Flat Top Pistons Promote a Better Flame during combustion and less prone to detonation using higher DCR.Why would you want to use a head that has an inferior combustion chamber?
I'll go there read the following ;o)Flow is important, but theres more things to consider when trying to make better than average power.
Ron, I allways like to argue with you, your old school and a car guy to boot, god bless you. I do feel the 820 chamber is inferior, please do me a favor, take your car to a drag strip, then please report on the MPH. I have no problem with your post, but I gotta tell you my heads hurting trying to follow it.It's not that the Combustion Chamber is inferior it's that Flat Top Pistons Promote a Better Flame during combustion and less prone to detonation using higher DCR.
In my case I'm running Speed Pro (TRW) Forged Pistons with a 25.7 cc dome with a Forged Rotating assembly. The 118cc Open Chamber of the 781's with a .019" Head gasket gives me a 10.2:1 Static Compression and about an Ideal 8:1 DCR with the SR Cam Profile I've chosen to reach 7000rpm with 460 cubes.
Because the 496 has bigger cubes your more then likely to use a flat top piston with say the 820 or 781 castings to obtain your desired Static Compression to run a Cam that will get the most out of Pump Fuel without detonating. A DCR no greater then 8:1 seems to be the accepted ratio to run Pump Gas without detonation.
You should be able to spin a 496 Cast Rotating assembly safely to 6400 rpm and choose a Cam that makes wide band Torque through to approx 6200 rpm - That's why I suggested the CC-XM278H-12 with say a 10:1 Static Compression 496 to accomplish an 8:1 DCR and get the biggest BANG out of Pump Gas and for the Buck.
Download and play with P. Kelley's DCR Calculator found here: http://www.empirenet.com/pkelley2/DynamicCR.html
With a 496 to reach a 10:1 Static Compression with say the 113cc 820 heads you going to need a Piston with a 10cc dome, or approx a 15cc Dome with 781 casting, or choose say a 98cc Closed Chamber with a Flat top piston running a .019 Head Gasket or you 0-Deck and run a .038" Composite gasket in order to keep the QUENCH a in a respectable .034" to .044" Range. Quench is a Critical Knock/Detonation Factor for extracting the most power out of Pump Gas with our Old LT1 and MKIV Mills.
If you Opt for Alu-Heads you have to 0-Deck as they use Composite Gaskets which are generally .038" thick = an Ideal Quench.
You will probably will get away with a .025"(OEM Deck Height) plus a .038" Composite Gasket = a .063" Quench with a 9.5:1 Static Compression (NOT 10 to 11:1) providing you keep the DCR below 8:1 through Cam Selection running Pump Gas.
I'm Old School and have been building Engines for 45 years. Here's the Top End of my Pump Gas 7000rpm 625Hp 460ci SR, 10.2:1, 8.1:1 DCR, MKIV with 781 Heads running a Lunati 502A1/CC-533 Springs & Crower HIPPO Lifters:
I NOT saying the 781 are the answer for your build and application but work for me; other then, I would prefer Alu-Heads to reduce the Weight for better Road Handling - My Z is a Road Warrior not a Drag Machine.
Doesn't mean, I can't do a 10 Sec 1/4 ;o)
What I'm trying to say is that: YES OEM Heads (Cast or Alu) are feasible for how you desire to Build and DIAL-IN an ENG - Believe me, GM progressed Specs better then either Ford & Mopar; YET, I have never been able to build one Better then the Other; so don't think the GM Camaro BBC Conquers All when a 1968 4 Cyl B21 Volvo will Wipe Your A**.
Mark, what is the answer? I'm going with the 702 heads for budget purposes only. I dont want to change over the flat tops in my motor so my choices are 8:1 with stock 781 heads or 9.5 : 1 with a set of big valve 702 heads that I have. Eventually I'm getting one of your motors but thats a year or two away.vortecpro said:Whats will make more power, a ported 9.5 comp 454 peanut port, or a flattop 454 with a ported closed chamber head (702)?
The quench matters with any compression. If you took a 9.5 comp 820 headed engine, then a 781 headed 9.5 comp engine everything else the same, which engine will be more efficent?Well I did comment that Quench is about inconsequential with a 9.5:1 Static Compression with a DCR is below 8:1; but, you will never approach 7000rpm with Pump Gas.
Not saying a 9.5:1 496 Cast Rotating assembly will not put out 500+ Hp at 5800 rpm on pump gas ;o)
I agree with you "Use a the Smaller CC Bath-Tub Close Chamber Head with a Cast Rotating Assembly 496, Flat Top Pistons." It's Practical and Least Expensive.
In Theory the Engine with the Lessor Dome Height. The 781 would require a Piston with 5cc more volume and therefore have a Higher Dome then the Engine running the lower Dome Piston and 820 Heads. So I would so I would say the engine running the 820 heads would be more efficient.If you took a 9.5 comp 820 headed engine, then a 781 headed 9.5 comp engine everything else the same, which engine will be more efficent?
I can't answer your question, but just by looking at the combustion chambers, you would expect the 820's to have a much larger chamber than the 781's, yet I believe the 820 is supposed to be 114 cc and the 781 is supposed to be 119 or 120 cc or thereabouts. Has anyone cc'd the 820's and/or the 781's to verify this? The guy who built my original boat engine selected the 820's because he thought they had a larger combustion chamber and would drop the compression down to a manageable 9.2:1. I am so confused right now I don't know what head to use on my next build.Hmmm...
Here is a 781 and 820 in pristine state.
On a 9.5:1 c/r 454 which head will be more efficient with all other factors the same (equal) and why?
