Brake booster problems
1 reading
1.1K views 2 replies 3 participants last post by  ohcscott
I just converted my standard master cylinder to a power booster M/C combination but i have a problem,when i get off and on them alot such as a drive thru or traffic jam they loose their boost which is atcually dangerous they are so hard to apply.I hooked them to the port on the intake behing carb.How would you check and troubleshoot this problem?
inspect the check valve too.
start the car and put your foot on the brake. you should have power assist at this time. keep your foot on the brake and shut off the car. if your pedal gets hard and rises up, replace the valve first. it is a one way valve which is supposed to hold enough pressure for a good 2 more brake applications when there is no vacuum. if, after replacing this ~$5 part, it still does it, you may have a bad booster. if the booster is leaking internally, you should be able to hear it hissing.
your engine also has to be supplying a good amount of vacuum for the booster to work. so in addition to checking for other vacuum leaks, if you have a major thumpity thump camshaft, you may need to get a vacuum pump, aux. canister, or use hydroboost instead.
