1 - 2 of 18 Posts
Are you using the metric rear calipers that use the caliper pads for the ebrake? If you are the ebrake must be adjusted or you will not have brakes....
Don
Yes I am and I worked the emergency brake lever until I couldn't turn the rotor by hand.
Those brakes are a giant PITA in my experience.... I installed a set on a 57 Belair and they were clocked such that the bleeder was not at the very top and you had to unbolt them and rotate them so that the bleeder was at the top to bleed them. Not sure if this is the case here....
Don
1 - 2 of 18 Posts
