There was some surface rust in the trunk of my '67 RS, so figured out that the water was getting in through the holes that were drilled for the spoiler long ago. Frankly, I'd rather not have the spoiler, but I would have to have the 8 holes drilled into the trunk lid filled and then painted. Maybe sometime down the road, but not just yet.
I took the spoiler off today, took the old hardware off, and then replaced with a few fender washers with matching fender rubber washers, and put a little silicone around the hole, which should stop any water from entering, and you can't really see it unless you are looking for it under the spoiler.
Well, I was putting the nuts back on, and two of the studs that are used to secure to the trunk lid snapped off, and they are both on the same side. The spoiler is stable due to the other 6, but is not locked down completely flush.
Aside from redrilling, any ideas on how to secure those two threads back? Would JB weld work or some kind of epoxy be strong enough to re-insert and bolt down once cured? Mind you, the thread shaft is surrounded by plastic in the hole.
Any help would be appreciated. Thanks!
