Hi guys, here's my current combo:
355 small block, 9.8 to 1 compression, Sportsman 2 heads (bowl blend, pocket ported, 2.02, 1.6 valves), 1.52 roller rockers, Performer RPM manifold, 750 vac secondary Holley, Comp Cams 280H cam.
I'm looking to get a bit more top end out of this engine as the car is built primarily for vintage road racing and it runs out of puff at about 6K. Could somebody please desktop dyno this combination and then try it with the compression ratio raised to 10.2 to 1 and a Comp Cams 294 solid fitted. I could bump the compression with a thinner head gasket as Comp Cams website says I need at least 10 to 1 with this cam. I'd love to see what numbers this makes and what shape the torque curve is compared to my existing cam.
Also, has anyone run with the 294S in a 350 and is there enough vacuum for power brakes?
Thanks in advance.........
69RR
69RR
