Hey Mike, I thought I might add my two-cents:
1) Longer Pitman and Idler Arms make faster steering.
2) Shorter Steering Arms make faster steering.
3) Closer ratio steering boxes (less turns lock-to-lock) make faster steering.
By closer ratio steering box, I mean 12.7:1 would be "closer." A 16:1 steering box ratio is a "wider" ratio.
The steering box gear ratio not only means "faster" steering but also fewer turns lock-to-lock. Its really the same thing. When setting up my '68, my first concern was fewer turns lock-to-lock because driving a 3.5 to 4 turns lock-to-lock car is down right annoying.
Having said all that, I have heard from a few people that if you pick all of the "fastest" steering components - long pitman arm, short steering arms and 1980s style IROC steering box with the 12.7 ratio, the steering can be very twitchy. More specifically, the comment I heard (but have not experienced) is that a "twitchy" car can be a handful when cruising at freeway speeds just trying to keep the car straight.
So for my car (which I have not driven yet), I chose the long moog pitman arm, short steering arms (they are the ones I had on hand) and a '60s era rebuilt 2.5 turns lock-to-lock steering box with a reported 14:1 ratio. I hope it isn't twitchy. I also am putting on 235-60-15 radials and a 1-1/8-inch sway bar so with the good tires I don't expect it to track but the suspension should be pretty tight with the big sway bar. I'm actually most concern about under steer. By the way, all of the above is with a power steering box.
I hope that helps but as I said, its just my two-cents.
